Redundant electric hot water tank
joncroteau
Member Posts: 53
hello- I had a new Viessmann installed last winter which also supplies my hot water. My 7 year old electric hot water tank is now obsolete in my system. It’s currently plumbed with shutoffs to isolate it from the new system. My thought was that I could use it as a backup if I should ever need it. Should I drain it or leave it full? It’s shut off at the breaker.
drain it and leave it open until you need it.
