Balancing system
Hi folks,
This year I decided to be super anal and balance my system. I had one radiator that hissed a lot at the end of the cycle so I decided to really look at all the radiators, when they got hot, when the shut off, etc..
I have a one pipe steam system with eight radiators on 2 floors.
All of the vents are Gortons and are 1 to 3 years old.
My hypothesis was that the radiator that was hissing was getting hot too early, the steam was condensing, and then it was reopening.
Now, however, all of the radiators are getting hot at about the same time, and almost all of them are hissing at the end of the cycle. This has to be an issue with the pressuretrol, correct?I was watching the gauge on the last cycle and it shuts off around 1 psi but it takes a few minutes for it to get from .25 psi to 1 psi and I think that’s the period in which all the hissing is happening. Is the solution to get a vapor stat? And really lower the pressure threshold?
Is there anything else it could be?
The boiler is regularly serviced and the gauge is one of the 0-3 PSI gauges.
I appreciate all pointers!
Mad Dog_2
    Jamie Hall Member Posts: 27,190
    That might help. You do have it shutting off more or less as it should — on that fairly rapid rise which indicates that everything is taking as much steam as it can — which is perfect.
    But… vapourstats aren't cheap, and the question is… is fixing the hissing worth the price to you? A cheaper interim alternative would be to get another — identical — vent from a reliable source and try putting that on. Some vents hiss more than others…
    Mad Dog_2
  • acwagner
    acwagner Member Posts: 515
    You could try adjusting the thermostat settings first. Depending on the model, it might have an option to adjust the temperature band the thermostat is triggered and then satisfied. If you narrow this range, the boiler will run for shorter periods but more frequently. Some only allow you to set the cycles per hour, which is a roundabout way to achieve a similar result.
    The goal would be to get the thermostat satisfied before the rads fill up completely and the vents close for each call for heat. That way the pressure won't build up enough during each cycle to make the vents hiss.
    Best to record your thermostat settings first so you can put it back to the original settings if things done work out. Also, make incremental adjustments and see how it goes for a few days before making new adjustments.
    Burnham IN5PVNI Boiler, Single Pipe with 290 EDR
    18 Ounce per Square Inch Gauge
    Time Delay Relay in Series with Thermostat
    Operating Pressure 0.3-0.5 Ounce per Square Inch
  • dabrakeman
    dabrakeman Member Posts: 979
    edited December 2025
    Or, look at your thermostat control and see if you can shorten your cycles a bit so you never build beyond the 0.25psi. Smaller swing temperature or higher cph. If with your balanced system you have all radiators hissing (thus filled) on a regular basis then it seems you are either running too long cycles, boiler way oversized, under radiated (unlikely), you are doing a recovery or it is near design temperature cold out.
  • ARobertson13
    ARobertson13 Member Posts: 128
    I you have a 3psi gauge and you measure a maximum of 1 psi, the hissing cannot be related to the pressure issues. A properly operating radiator vent should have no trouble closing at 1 psi if it is hot enough. They should also stay closed even if the steam has condensed. Are they hissing before or after the steam is shut off?
    EBEBRATT-Ed Member Posts: 20,051
    Is the venting on your steam mains adequate? Is the hissing you hear the air/steam coming out or air rushing back in when the boiler shuts of?
  • dabrakeman
    The OP said he has radiators starting to hiss when pressure rises from 0.25 to 1 psi. If pressure is rising and assuming this is all well after the main vents have closed then likely the rise is due to one or more radiator vents closing off. It is possible the pressure could rise from .25 to 1psi upon closing of the main vents but that would signify to me a very oversized boiler or very slowly venting radiators. One should still be able to stay well below 0.5psi before any of the radiator vents close.
    OP, cna you clarify whether when the radiator vents are "hissing" whether it is just air escaping the vent (last sections of radiator still not hot) or wehther the radiator is hot all way across and you have some steam escaping the vent? You may need to use a mirror over the vent to tell if steam is escaping. If so the vent is failed.
  • gfrbrookline
    gfrbrookline Member Posts: 788
    I agree with @EBEBRATT-Ed Sounds like you need more main venting.
