How to delete boiler coil and replace it with a HPWH
2»
  • nelaco
    nelaco Posts: 21
    Well, the coil is leaking inside the boiler so it is history. When I flushed it, the bucket kept rising in water level. Lowe's postponed the delivery of the HPWT from last Friday to tomorrow…fun times.
    @EdTheHeaterMan , I just tried this but the wires won't come off. Do I need to take the white box appart and undo them from the inside or just pull them very hard? I am planning to replace the coil since I already have a new one that I bought months ago that I can't return. It would be nice to have it as a backup and would also solve a small leak by the coil cover.
    "L8184A,C,G or L is easy to do by removing the Rand W wires from the LO limit side of the control and connecting them together. That changes the control from a maintaining minimum temperature for DHW to a cold start boiler."
    Thank you!
    EdTheHeaterMan Posts: 12,951
    edited December 2025
    To remove the wire from the white aquastat: use a pocket screwdriver to depress the release and the wire will pull right out.  the small rectangle next to the wire opening is the release.
    Don't take the white box apart
  • nelaco
    nelaco Posts: 21
    Yep, now that you pointed it out I see it. Thank you @EdTheHeaterMan !
  • nelaco
    nelaco Posts: 21
    I finally got the HPWT yesterday and installed it. I am so impressed! What a difference. Not only we are getting plenty of hot water, but also a lot more pressure than before. Very happy with the purchase. It is a Rinnai REHP80.
    Of course now my boiler is getting too much pressure. I already called the service to come take a look. I get about 32 PSI. The coil is 100% isolated so I am not sure where the extra pressure is coming from. There is not city water going into the coil. The expansion tank is about 3 years old. We'll see what they say.
    Thank you everyone! Appreciate all the help!
