Furnace stack temp
aboucher
Member Posts: 1
in Oil Heating
Stack temp of hot air furnaces- what are you guys considering acceptable stack temps? I recently replaced the furnace at my house and I’m averaging a 550 stack temp, which seems high but I usually only work on boilers so I don’t really know.
Airco/ECR BCL-100
Beckett AFG- burner sold with furnace
.60 70w at 140 psi
0 smoke
6% o2
-.02” draft at breech
5 in flue 5 foot run 2 90s into clay lined chimney
70 degree return
125-135 discharge
Return plenum is 20x18x20 open at the top
Unit serves 1100 sq basement
- 116 Geothermal
- 52 Industry Classes
