DHW Recirculation Is Great!
Was this a dedicated return line or one of those cross connect valves that gets installed under a sink at the farthest point?
A dedicated return line.
you will want the entire loop insulated or you will have a some heat loss and increased fuel bill.
Worse if it runs all the time. If it is on demand that would be less heat loss.
But a DHW recirc loop is basically a small hydronic heat loop.Bob "hot rod" Rohr
I put a 4 gallon mini heater in the basement just below our kitchen sink, and we get hot water in less than 5 seconds now instead of 30. I like this plan because it puts less stress on the plumbing IMO.
Continues circulating system cost an arm and a leg to run. Disconnected mine. Now I just run the hot water in the tub and have quick hot water. Water is cheap.
- 50 Industry Classes
