DHW Recirculation Is Great!
Finished the install and wow! Maybe 10-15 seconds and there is hot water in the shower at the other end of the house.
GGross
  • Le John
    Le John Posts: 250
    Was this a dedicated return line or one of those cross connect valves that gets installed under a sink at the farthest point?
  • A dedicated return line.
    hot_rod Posts: 28,705
    you will want the entire loop insulated or you will have a some heat loss and increased fuel bill.
    Worse if it runs all the time. If it is on demand that would be less heat loss.
    But a DHW recirc loop is basically a small hydronic heat loop.
  • Bob,
    It is on a timer and I only need it to run for less than 1 minute.
    hot_rod
  • MaxMercy
    MaxMercy Posts: 632
    I put a 4 gallon mini heater in the basement just below our kitchen sink, and we get hot water in less than 5 seconds now instead of 30. I like this plan because it puts less stress on the plumbing IMO.
  • Continues circulating system cost an arm and a leg to run. Disconnected mine. Now I just run the hot water in the tub and have quick hot water. Water is cheap.
