Need help finding a small boiler burner 12-15Kwh
Hello, I'm considering DIY and custom make a central diesel boiler for my living boat. I've come to the conclusion that I need about a 12-15 kwh burner to heat hot water for both regular use and cabin heating. The problem is I can't find burners that small. Thanks for good advices and tips :)
that is about .3gph if my math is right. i'm pretty sure most smaller oil burners can be set up for that firing rate
12-15 kWh thermal = 0.3-0.35 US gph. Don't think I've heard of a nozzle under 0.5, in the US at least.
Bburd0 -
Thank you, Mattmia2, that's good news. Can you please recommend a burner that is easy to set up? Maybe I should leave the nozzle job to someone who can adjust the burner for an optimal, clean burn.
Look to the boat, Dickinson Marine and RV industry for gasoline and diesel heaters in small sizes. You will find air, hydronic and some combined heaters for DHW and heat.
There are also some wood fired versions. I have. Cubic Mini wood burner in my camper, originally designed by a sailer for his boat.
Living the hydronic dream1 -
Thanks, I found a used burner (2019) Fremo type K-3 18kwh with 0.5 nozzle for 100$.
what type of homemade boiler? That gun needs to fire into a combustion chamber with a bit of design engineering thought.
Too much HX surface area and you will get condensing, too small maybe impingement, hot spots on the metal..
remember that most burners run at a higher pressure than the nozzle's gph rating is specified at.
