Navien universal temperature sensors
cm6230
cm6230 Member Posts: 19
does anybody use the navien universal temperature sensors you can buy and zip tie on to the supply and return? What’s everyone’s experience with them? Are the accurate?
    EBEBRATT-Ed Member Posts: 20,164
    Don't know about Navien but sensors are frequently strapped to pipes. You may want to use a hose clamp instead of a zip ty depending on the temperature and insulate it.
    cm6230
    hot_rod Member Posts: 27,446
    pretty much any metal sensor could strap onto a pipe, it needs to be a tight connection, no air space
    Thermistor type sensors have the thermistor at the very tip Thermistors are generally pretty accurate
    Insulate around the sensor and clamp
    cm6230
