Navien universal temperature sensors
does anybody use the navien universal temperature sensors you can buy and zip tie on to the supply and return? What’s everyone’s experience with them? Are the accurate?
    Don't know about Navien but sensors are frequently strapped to pipes. You may want to use a hose clamp instead of a zip ty depending on the temperature and insulate it.
    cm6230
    hot_rod Posts: 28,705
    pretty much any metal sensor could strap onto a pipe, it needs to be a tight connection, no air space
    Thermistor type sensors have the thermistor at the very tip Thermistors are generally pretty accurate
    Insulate around the sensor and clamp
    cm6230
