Is it a bad idea to use galvanized pipe and fittings in a closed-loop 100% water hydronic system?
I stumbled into a bunch of galvanized fittings and pipe from an auction. Even some large 2" diameter ones to potentially make-up a "short and fat" header for a 3-pipe buffer tank setup for my heat pump hydronic system.
I've read how black iron should be used instead of gavanized, but how much am I really risking in future issues with my non-glycol, naturally soft water (I'm in the moutains of Colorado, so it's all snowmelt) in my hydronic system?
    Jamie Hall Member Posts: 27,357
    It has been my experience that galvanized steel piping corrodes (rusts) incredibly fast. Black iron doesn't.
    hot_rod Member Posts: 27,446
    my understanding is the concept of dissimilar metals copper and zinc, with an electrolyte can cause corrosion
    In an open loop system you need a dielectric union or nipple between the two different metals
    You could use a brass nipple between the copper to galvanized connection
    Galvanized into the tank Is not an issue , if you use brass iso flanges on the pumps you are covered
  • EPMountainMan
    EPMountainMan Member Posts: 10
    Thanks, guys!
