What is this?
Gateacre
Member Posts: 106
Found this near an old heat exchanger at the highest point in the building. 2p originally coal fired. Clearly a vent and I'm aware of coal burners with vac vents to produce steam below 212F. Is that what this is? I don't see how it sealed against steam though. Weighs a ton.
That would make sense since there were no main air vents on the system in the coal era.
- 117 Geothermal
