Peerless WBV
BDR529
BDR529 Member Posts: 376
Now has baffles from factory. No very robust for where they have to live.
I see heat distortion to the point that they can not be removed and sooting issues from there.
Anybody else?
    HVACNUT Member Posts: 7,436
    It got a complete makeover. I don't see any baffles though. I wonder if the burner door swings open wide enough with that framing.
    109A_5 Member Posts: 3,988
    The way I see it Water or Steam they both have the baffle, item #17. Sooting issues ? Does the boiler need a tune up ?
    Maybe the baffle is for low firing rates?
    Big Ed_4
  • BDR529
    WBV's always tuned very well. I figure the baffles are to drop temps to get "better" Effcy numbers.
    Not even going to get into condensation discusion.
    What is figure 8.1? Correct castings but, 16 17 19 20?
    Oh! The really new model. But no baffles..
    I give up, As long there is no subcription fee , bluetooth BS. Baffles are easy to deal with.
    I've never seen the new design in real life. I wonder if a Riello with its cover fits under the boilers burner cover. No more front return either.
  • SuperTech
    SuperTech Member Posts: 2,661
    I've seen these baffles in new WBVs and it seems like they cause problems. Over fire draft is positive unless I remove them. It's hard to get clean combustion with them in. My company just removes them when we come across them. We treat them just like vent dampers, we keep the vent dampers open to avoid problems when they get stuck open. Both items are unnecessary things added in a attempt to gain a tiny bit of efficiency.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,590
    They were added to meet DOE AFUE standards
