Baffled: Weil-Mclain startup and delay on break relay
I wish I could take credit for it but it was basically @EBEBRATT-Ed idea. It seems to solve the apparent changing load characteristic of the damper. I just integrated it into the Ladder Wiring Diagram for the boiler.
One Pipe System0 -
@109A_5 … That sounds like @ ED. He really likes those RIB relays. Nice Diagram.
I do like RIBs. esp. the RIBU1C
The idiot light. NO or NC, 120 or 10-30 volt ACor DC coil. $16
Very handy.
One note - I've got the '3' and '1' terminals connected as shown here; this seemed to me to be the right way to do it based on my understanding of the 32392/ICM203. (I.e., in this diagram we'd be "looking at the timer from behind.")
I haven't tested to see if it makes a difference in this setup, but apparently it might in some applications…
Anyway, I post this because I will update the OP on this thread with the solution for future searchers and wanted to be sure we have all things accounted for.
Although I did see it in that YouTube video that the person in the video complained the timer was hooked up backwards (with no real demonstration and resolution in the video, I think there was other issues), I would say in this case it does not matter. IMO it does not matter which way terminals 1 and 3 are connected, for two reasons, first it is a series circuit (it's only a two wire device), also it is an AC series circuit. Secondly (at least with the ICM203F) the terminals 1 and 3 immediately goes through a bridge rectifier circuit inside the timer and it does not care either way about terminals 1 and 3.
Your connection details may be helpful to others if they have never worked with relays and/or this type of timer before.
Thanks.
One Pipe System1
- 120 Geothermal
