Guidance replacing water heart gas valve
ratio
Member Posts: 4,234
Any tricks for swapping out the electronic gas valve on an AO Smith power vent model? It looks simple enough, just spin the old one out & the new one in, but I've never removed a valve like that.
I'm thinking break the valve loose with the tank full, then drain it. How hard will it be to turn it? If the anodes I've pulled out are any indication it's going to be rough.
Came right out, the nipple that sticks into the tank is plastic. I was worried about it for no reason.
The new valve, however, gives an 8-2 flash code: temperature sensor fault detected. 😞
did you check the output of the thermopile?
