circulation pump recommendation
rumn8r
Member Posts: 105
I need a recommendation to replace 20 year old Grundfos UP 26-99 F circulation pump in a 16 valve hydronic in floor heating system. Thanks!
If it has zone valves or zone actuators, look at a delta P circ.
I've had excellent luck with the Grundfos Alpha series. Alpha 26-99 in you case. Assuming the pump you have now is sized correctly.
Living the hydronic dream1
