circulation pump recommendation
I need a recommendation to replace 20 year old Grundfos UP 26-99 F circulation pump in a 16 valve hydronic in floor heating system. Thanks!
    hot_rod Posts: 28,705
    If it has zone valves or zone actuators, look at a delta P circ.
    I've had excellent luck with the Grundfos Alpha series. Alpha 26-99 in you case. Assuming the pump you have now is sized correctly.
    https://www.facebook.com/watch/?v=2111692822522929
    GGross
