what cause flame to burn inside burner tube?
Joseph_4
Joseph_4 Member Posts: 320
edited November 2025 in Strictly Steam
I have a customer with an old enerjet boiler. it lights up violently and flame burns inside burner tube usually for a bit then flame moves to time of burner tubes. what causes this and how can i correct it?
Thanks
Joe
    mattmia2 Member Posts: 16,673
    did you pull the burners and look at them? i know there are some burners of that style that degrade internally and cause rollout like that.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    What is the gas pressure ?
  • ScottSecor
    ScottSecor Member Posts: 1,033
    Oftentimes this is a result of low gas pressure. Check the gas pressure with all of the gas appliances running. For example, turn on stove, water heater, dryer, etc.
