Spill Switch Question
Cyclist77
Cyclist77 Member Posts: 259
OOn A Weil-McClain CGa3 the manual shows and says the Spill Switch is to be oriented toward the front of the boiler.
Is there a specific reason? Why can it not by in a different orientation?
  • Easier to see, I suppose.
    HVACNUT
    HVACNUT Member Posts: 7,426
    As long as the factory wiring reaches with slack, it can go in any degree. If the front of the boiler is at 6 o'clock, mounting the Spill Switch at 12 o'clock is safe, but the wiring won't reach. And even if it did, you don't want it going around the hot flue pipe.
  • Cyclist77
    There is enough wire for it to be located at 3 or 9 o'clock. But Weil-McClain was adamant in an email that it need to be at 6.
    I would like it at 6or9 so it is out of the way of a manifold.
    IDK why that is. Its not like a backdraft knows to go to the front of the boiler. Did WM say why they were adamant?
  • Cyclist77
    No,he just made reference to the manual and said it must be oriented as shown.
    Thanks for all your replies!
