Navien 3 way valve replacement NCB 240 H
jeffceo
Member Posts: 27
Hi, I have a newer NCB- 240 H combi. The 3 way valve is the newer cartridge style. I pulled the locking pin out but I can’t get the 3 way valve to pull out more than a 1/4”. Am I missing something? Thank you!
There is no mechanism other than the locking pin that prevents the three-way valve from being removed. It is a smooth chamber. I'm assuming you are changing the valve because it's not working, but it could also be broken physically. if the white plastic in the middle is broken it's possible that it's catching on one of the outlet holes. or the plunger piece at the bottom is not perfectly straight and is catching at the end.
2 -
Thank you. I ended up replacing the entire 3 way valve assembly including the motor cartridge and housing/ pipe. There was no way I could get the old valve out of the housing without breaking it0
Engineering has never been their strong suit ...
Well, now that the entire assembly is out.. have you tried taking out the valve after?
I had both the valve and housing in front of me and was pushing it in and out without issue without possibility of another inherent mechanism/part getting in the way.
So I am very curious as to what was preventing the valve from being pulled out! Useful knowledge especially for future cases..0 -
I haven’t tried getting it out on a workbench yet but I will. You’re right, it will be useful knowledge. I’ll report back tomorrow.0
First post here but have been lurking for a long time. Just encountered this same exact issue on the Navien NCB 240H in my house. The 3 way valve was only pulling out slightly, but being that it was my personal boiler, I took a chance and muscled it out. Once removed, I cleaned out the housing a bit and installed the new one with no issue.
I couldn't tell you what was preventing it from sliding out smoothly aside from some minor scaling inside the housing. The unit is only about a year and a half old and I just serviced and descaled it a month ago.
Realize this post is responding to Oct 23 string but have same interest but cannot locate a supplier for Navien 3-way valve, PN 30020637A. I checked all the popular suppliers online through websites. Many other Navien 3-way valves are available but not this one. Is there a compatible replacement PN?
I had the same problem could not remove the motor and cartridge had to change the entire valve and it was difficult removing and reinstalling the 2 bottom screws
Its easier to replace the whole valve assembly. I disassembled the LLH to get access to the rear screw. Very poor design.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
