Steam Boiler
Hi Everyone,
Attached is a photo of my heat exchanger. Is this 100% a leak? It had scaling but I've ever seen a water leak or steam.
How often and how much do you have to add water to this boiler? It sure looks like a leak to me.
See my sight glass boiler videos: https://bit.ly/3sZW1el3 -
Yeah that is definitely leaking somewhere. Ideally you'd want it to fill less than once per month during winter. it's not even winter yet.
(Actually ideally you'd fill it manually and not let it get low enough for the automatic feeder to kick in. This lets you have a better idea of water usage)
I had one company say it's fine to run and another say its not safe. I still haven't seen any water leakage or an indicator that steam is hitting the cover.
The water leakage is evidenced by all that crusty white limescale deposit. I can't speak to how safe or unsafe it is, but I don't like stuff falling onto my burner tubes.
