What say you ? She’s steaming
Started her up and saw this after about 20 min run. Steam coming from top of boiler.
In all likelihood, boiler needs to be replaced. Hard to tell from the video. Are you sure it's coming from the boiler and not from the glass or something like that?
I took the top off and found where the steam was coming from.
Is it safe to run like this ?
I’m assuming I need a new boiler asap.
It's safe enough as long as you keep water in it (water is always escaping as steam from it while you run it, as you have seen).
You might be able to smear some jb weld in/on that hole to buy a little more time. Run it at a very low pressure (it likely can't build much pressure anyway)
Does it heat your building currently?
You are losing a lot of heat energy up the flue but it can carry you for awhile maybe. Yes you need a new boiler.
Thank you
The steam is not good for the chimney.
At this early stage of the heating season, I would recommend replacing ASAP
Well it won't be steam for long 😂
So JB Weld is safe to use. It does heat everything up nicely. It’s a grossly oversized boiler. Going to reach out to NE Steam Works to replace.
The moisture is really the issue
@New England SteamWorks is excellent.
I don't think that is a part of the hx that connects to the firebox and flue collector, i think it is just leaking out in to the basement.
JB weld or jb weld putty will be fine there because it won't get above steam temps because that part doesn't see combustion products. I wonder if you can mix putty and the paste to form something that won't run but is softer than the putty.
2 -
JB Weld Marine and you should be Ok.
Don't poke around the rust too much as the are around might be holding up by a prayer.
https://www.youtube.com/@HeatingBlog1 -
Sure but we're not talking long term here. And there's tons of moisture in combustion gas, no?
I'm starting season 5 on an old boiler with a leak similar to (though not as bad as) yours. Patched it with JB Weld and a piece of steel formed to cover the hole. Works great and looks the same today as it did 4 years ago. JB Weld handles 200º-ish just fine. Give the epoxy a good substrate to bond to; diligently clean off ALL the rust in and around the hole. Use a vac to suck it up while you work. You don't need the epoxy to fill the hole; encircle the hole with it, embed the steel piece in it, and cover the edges to hold the steel in place. Should get you through the season no problem.
FWIW, here's a pic of my patch.
https://us.v-cdn.net/cdn-cgi/image/quality=80,format=auto,fit=scale-down,height=2000,width=2000/5021738/uploads/editor/z5/8770yibb6af3.jpg
1950 Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.
2 -
As pointed out above, I misspoke, as this leak is not in the combustion area. So chimney is not of concern in this particular scenario. But steam will absolutely eat away at the inside of chimneys. Of course there is moisture in combustion gases, but the steam will generate considerably more moisture. And will presumably cool down the chimney.
1
- 117 Geothermal
