Flue liners hindering check of flue
My son’s chimney has an aluminum Flue liner. Utica. Boiler manufacturer, suggest putting a mirror in the flue at the bottom of the chimney. When I do so in broad daylight, I cannot see any sunlight.
Is this normal?
Too many questions open. Is the mirror even in the liner? Or does the liner stop further up? Is the flue straight or does it have an offset? Is there a flue cap?
And,, what is the concern?
so, the liner is continuous from a 90 degree turn in the basement, to the top of the chimney, a distance of approximately 34 feet or so.
There is a rain cap on the top.The flue is straight
I did put the mirror into the liner until it encountered the far outside edge of the liner, but saw no light at the top.
The concern is that I cannot verify that no animal or bird has made a nest out of the liner during the summer months
You’re not going to be able to see up the chimney. It should have a cap with the liner. You may be able to send a boroscope up there to get a look.
But probably the only true way to inspect is by dropping down a camera.0 -
Probably in the OP's case the liner goes a little long horizontally then sweeps up. I have a boroscope about 30” long that works pretty good in this case. Basically just showing a full round or square bright light indicating no obstruction…unless theres an offset.
the cap may be keeping the light out
