Replacement for a Wilo Nr.4107501/10w23 Typ Star S 16U-15-130 pump
I have a SunMaxx, IntelliSol DHW Plus control station servicing about 60 evacuated tube collectors on my DHW system. It was installed around 2006 and has been working flawlessly. It is reaching the end of its life , but I hope to keep it running for a while. I need to replace the WILO pump and am having a hard time finding a direct replacement. The pump was stuck, very hot, and not moving any fluid. After playing around with it, I got it to circulate, but it doesn't even move the flow meter.It is a
I found this on Amazon,
but I don't know if I would be able to swap the motor onto my current flange, which is connected via union nuts. Would I be able to just unscrew the pump from the flange of the new one and screw it on to the current flange on my system?
Any advice would be helpful. Here are a couple of picts of the setup.
Thanks.
