Replace AUBE telephone controller w/ WiFi controller
Good morning,
I am looking to replace a pre-exisiting AUBE telephone controller:
https://www.amazon.com/Honeywell-CT240-01-Thermostat-Phone-Controller/dp/B001QFZ3ZK
With something that is WiFi controlled but essentially, does the exact same job. Which is to set the boiler's controller (which is a Tekmar) to occupied or un-occupied.
Of course I've done the google searches, but am having a really hard time to find something that meets my description. I have to think that there is something like this available somewhere. Perhaps, I am not looking in the right place.
Would anyone here have any suggestions or recommendations? Appreciate the help in advance. Thank you
  • mackenzo
    mackenzo Member Posts: 2
    Did you ever find a solution? I have the same problem. Since I changed my landline to VOIP, the controlled doesn't pickup for remote usage.
  • adambuild
    adambuild Member Posts: 422
    why not use a WiFi thermostat? I have three Honeywell RTH9585WF thermostats at my second home and they work flawlessly.
    mattmia2 Member Posts: 15,236
    there are lots of generic automation controllers out there, any one of those would work
  • mackenzo
    The CT240 toggles all 12 thermostats, my water pump, and the whole house heat exchanger. Are there wifi devices which would replace that funtionality?
    Thanks,
    Ken
