New press
I have an older press from Ridgid, it can’t be repaired anymore. Ridgid giving me a $500.00 credit towards a new press only. Would you get the 350 or the 351?
iron man, which one is more practical?
What ever you select, there will always be that one place that the other one would work better. Ask me How I Know?
Pistol grip is ergonomic for doing many fittings like installing a boiler with 5 or more zones
What Ed said.The barrel grip may get into some tight places better, but the pistol grip is more ergonomic.
Either way, you have to think through your piping layout so that you don’t press yourself into a corner.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.2 -
I have a Ridgid barrel grip tool and it’s been fine.
Whichever tool you purchase, get the additional ring set for when you do “press yourself into a corner”.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
of course that leads in to you might as well preassemble a bunch of it outside or in an open space and use sweat fittings for that part and save a ton on fittings.
I have the barrel grip with the rings. For me that's the best for smaller work, and repairs, and especially for working by yourself. Using rings slows production. But if you already have the regular jaws, get the kit with the barrel grip and the rings, then you'll have both.
I also have the larger one which is a pistol grip for mega press.0 -
I priced a ring sets for a Ridgid barrel grip unit but backed away when I saw cost was about the same price as I paid for the kit with tool and four standard jaws.
@PC7060 Yes, but the rings get you out of a lot of jams. With just the tool, you can only work on one plane; the rings offer innumerable angles.
Two btu per sq ft for degree difference for a slab1
- 50 Industry Classes
