Boiler feed pump tank
gunn308
gunn308 Member Posts: 18
Hi All, Had a brain cramp today after spending the better part of the day cleaning the float valve and flushing the tank in a Hoffman boiler feed pump. Why can't we cut an access in the top of the tank and then weld a flange on so we can screw it back on with a gasket then we can clean all the gunk out. It's all open to the atmosphere so there's no pressure. Tell me why it won't work?
    EdTheHeaterMan Member Posts: 11,982
    I would go for it.
    Intplm.gunn308
    EBEBRATT-Ed Member Posts: 20,044
    No reason not to.
    gunn308
  • gunn308
    Thanks for your positive reinforcement. have a buddy welding on a flange new float assembly will be here today.
