SGO vs EC
GW
GW Member Posts: 5,184
Steam Dudes thanks for the help on my pick up question, now I'm hunting for a boiler.
Pros/Cons with w/m SGO-7 vs the Peerless EC-05?
Gonna stick a gas gun on it
I can't find water content on the SGO. EC seems to pack a good amount of water
EC pipes off the taps with 2", that saves a few bucks.
EC is a bit lighter, Taller (easier to handle)
EC can handle several firing rates.
W/M seems to be a little less dough
Question, i haven't split a new block in all my days, is it a pain to put back together (expect a leak)? What is the gasket material and would i want new gaskets? I'm guessing just one split would be fine, the access has some stairs but we have the Lectrotruck
Thanks
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • GW
    another factor, Carlin is OK with the small EZ burner on the EC 05 but for the SGO seven section they 201gas, which is not readily available
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    EBEBRATT-Ed Member Posts: 20,145
    I never split one but have assembled many larger boilers that you can't buy in block form. Never had an issue.
    They should give you a gasket kit. I know the Weil Mclain is rubber gaskets. I don't know about the Peerless, but I think they use CI push nipples I could not verify this online. It's pretty much just 3 gaskets (Weil) or 3 Push nipples (Peerless) and some ceramic rope. Maybe some adhesive
    So the Weil may be a bit easier to split and reassemble. You May be able to find a supplier or Carlin that has the larger burner available
    GW
  • GW
    Thanks we may roll the dice and try to move it it one piece; just not a super easy route. I'll let my guys decide (we will all be at risk). But it will good to have a 'split it' plan
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
