Burnham MPO
BDR529
BDR529 Member Posts: 376
Anyone running a MPO189DV with the NX? Those Hagos are gold and Beckett seems to be scalping them.
  • HydronicMike
    HydronicMike Member Posts: 302
    Are you running it direct vent? If not, I wouldn't. If you can't get a Hago, you'll have to substitute and test.
    techforlife
  • BDR529
    Direct vented, yes for 8 years+ , No other option, Runs incredibly well..
    No Riello option either, NX or nothing.
    The Hago is magic in this application.
    Steamhead Member Posts: 18,331
    Which Hago do you need?
    Consulting
  • HydronicMike
    You haven't tried or won't try a different (substitute) nozzle? If you called Beckett, they'd probably tell you to try a solid Delavan, do full combustion and go from there.
    EdTheHeaterMan Member Posts: 11,810
    Are Sid Harvey labeled nozzles still rebranded Hago nozzles?
  • techforlife
    techforlife Member Posts: 127
    Hago H, SS, ES, P, B, what you looking for?
  • BDR529
    Hago 100 45 B Nothin at Webb CD either. Very little Hago stock at Sid Harveys, Webb nozzles were rebraded Hagos as well, nothing in stock even the common players. 80 degreee H,B forget the SS
    Most supply houses tell you they have it but you ask them to confirm it is not a Delavan and, well.. "It says you can run that" I know how that goes.
    Not trying a different nozzel and going down the combution test route. there is a reason why Beckett chose Hago. Boiler runs Flawless.
    Dose Beckett have them? Yes. Beckett is scalping them, Through the roof special order. Buderus LoNox territory and then some.
    Danfoss bought Hago some time ago and discontinued a bunch of their product lines.
    If that were my customer and I couldn't get the Hago, I'd try a 1.00x60B Delavan. This sounds screwy, but as I understand it, for an advertised spray angle Hagos were actually a bit wider than Delavans. Of course I'd verify it with a combustion test, as I always do.
    Consulting
    EBEBRATT-Ed Member Posts: 19,947
    Nozzles last a long time as long as you have clean oil. No need to change them every year. They can go for years.
    HVACNUT Member Posts: 7,333
    Screenshot_20251011_064907_Samsung Internet.jpg Screenshot_20251011_064951_Samsung Internet.jpg
    The squeeze is on.
    Robert_H
