high velocity ac
I am looking for 6" or 7" round duct insulated inside for hi velocity does anyone have any suggestions or thoughts
Diameter size of plenum is specified by OEM and insulation is external. As @pecmsg said, position and spacing of takeoff must be done per manufacturer instructions as does the length of the individual runs. Typical runs are 10-15 feet with balancing attenuation disc instance at plenum takeoff based on the design flow of the line. Final 3’ of each run is the sound attenuator. Runs longer than 15’ total have significant loss of flow so design is critical.
The insulation inside the duct is for noise reduction since high velocity air systems are usually noisy. I am retired and have been for quite some time but the only high velocity systems I can remember were from the pre1970's.
