Type thermostate logano g115
1990421 Member Posts: 1
i have a oil heater duderus g115 and i dont have the book and the wire thermostate diagram … someone can help me ?
  • psb75
    psb75 Member Posts: 1,120
    All of that information should be available on line. What is your question beyond that?
    HVACNUT Member Posts: 7,402
    What is PH-HK1 connected to? 63 is 120v. 61 is neutral. As long as its not a 230v European Logomatic. But that terminal block is for the space heating control circuit. These systems were designed for constant circulation.
    This is one example.
    Download the 2107 Installation and Service manual. You're going to need it.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,509
    Don't get confused with a Buderus room sensor ,which connects to that wiring block .. Normally the thermostat is run to a circulator relay ..
