Taco 007e circulator and Webstone isolator flanges which gasket?
micky
micky Member Posts: 2
edited September 25 in THE MAIN WALL
Hi all and thanks in advance for any and all help. I have looked around on the discussions here about flat gaskets vs the square "O-ring" gaskets but haven't found a clear answer — at least to my understanding. So, with the current Taco 00 circulators and the current Webstone Isolator flanges with rotating ring which gasket works best? The square "O-ring" provided by Taco or the flat gasket provided by Webstone? Thanks again!!
    Alan (California Radiant) Forbes Member Posts: 4,623
    edited September 25
    The former. There is a square depression in the Taco pump flange to accept the their square gaskets.
  • micky
    Thank you Alan!! The simple answer I was looking for.
    EdTheHeaterMan Member Posts: 11,506
    edited September 25
    Sometimes I find that the center flat of adjustable flanges don't line up so well with O-ring gaskets. Then I would use the Webstone gaskets. Otherwise I agree with Alan
    hot_rod Member Posts: 26,389
    That circ uses a large diameter square o ring, in some cases it does not seal on the flange face
    Some installers use both the o ring and flat gasket, others just the flat gasket
    It really depends in the specific flange design.
    Ive found swivel flanges work best with the flat gasket
    Miata
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    Taco recommendation is use square cross sectional O-ring. I can remember when some installers doubled up using both the oring, and flat gaskets, but that’s not recommended
    Joe Mattiello
    Taco Comfort Solutions
