Need Help replacing a Steam Trap
Hi there!
I am replacing a Steam trap that failed and I nee help finding the right language for replacement. Here is a picture of the steam trap:
There are no identifying marks on the trap itself. I think they have been lost to time.
    Take another picture so we can see the top of the cover as well. Take the dimensions. Send both pictures and dimensions to Tunstall in Chicopee, MA and they'll get you set.
    109A_5 Posts: 4,759
    edited September 2025
    Often to just freshen up the trap you just take the top cover off to replace the internal capsule or cage unit. Removing the whole trap is more unnecessary work. Sometimes the cover has to be changed too to accommodate the new capsule / cage unit.
    If you choose to change the whole trap the Spud (Red arrow) needs to be changed too, so it matches the new trap and does not leak. This may require a spud wrench.
    Name may be under the paint or on the cap. Tunstall may know just by looking at the picture
    took some mineral spirits and wire brush to the top and found SOME info.
