Why purge valve above boiler? Pumping Away.
AlwaysLearning2024
AlwaysLearning2024 Member Posts: 119
edited September 2025 in Gas Heating
Hi everyone!
Learning more about pumping away techniques and @DanHolohan writings and examples.
In one of this videos, he explains a simple way to purge the air from a single, hydronic boiler using a drain valve that is located on the supply directly out of the boiler. Curious why is specific location is chosen. Why not on the return side of the boiler?
I'm assuming this is so any air that may be in the boiler is also purged?
Thanks for any help!
