Will I have to drain my whole heating system?
scatgo
scatgo Member Posts: 75
edited September 2025 in THE MAIN WALL
Will I have to drain my system to replace the section of leaking pipe between the supply valve and what i think is a pressure reducing valve? And what is the red gizmoe after the PRV?
    hot_rod Member Posts: 27,415
    is there a valve to the right if the two red valves? You need to isolate both sides.
    The red valve on the right is a pressure relief valve. If you have one on the boiler you do not need that
    You should however have a backflow preventer at the fill valve
    And if you do need to drain down, replace the relief valve on the boiler
    Buy a combination fill/ BFD
    mattmia2 Member Posts: 16,691
    if it is the relief valve there should not be a valve between it and the boiler.
    scatgoEdTheHeaterMan
    EdTheHeaterMan Member Posts: 12,132
    YES!
    scatgo
  • scatgo
    Thanks for the help everyone.
    Peace
