Radiator shut off valves
Ghynes440
Ghynes440 Member Posts: 61
I am replacing a few shut off valves on my hot water radiator system, since we are switching boilers next week.
Do I HAVE to replace the nut that is threaded into the radiator that requires the spud wrench Or can I just reuse it on the new valve?
Do I put blue teflon tape on the threads of it?
    EdTheHeaterMan Member Posts: 11,811
    edited September 2025
    The nut that is connected to the Spud in the radiator is a matched set with the valve. You will need to replace the spud in the radiator unless you can find the exact make and model of the valve you are replacing. (unlikely)
    here is the tool you need to replace the fitting in the radiator and install the replacement spud. Spud Wrench
  • Ghynes440
    thank you, I just ordered one on Amazon. Luckily I only did two so far so I will just replace the spuds real fast tomorrow. I ended up getting an old rusted radiator sandblasted and powder coated for our bathroom. I wish I could do it for all of them in the house!
