Forced hot water heat options in small pantry?
2»
    pecmsg Member Posts: 7,020
    so he’s giving you a 10 warranty parts and labor on that set up?
  • TheUpNorthState88
    TheUpNorthState88 Member Posts: 111
    I would not put anything in for such a small space. Just leave the door open and that will let enough warmth spread in.
    Lifelong Michigander
    -Willie
  • kmdigital
    kmdigital Member Posts: 2
    If it's in fact a pantry, where food is stored, particularly things like potatoes, then I definitely wouldn't heat it. Yes, it'll definitely be a bit cooler, but that's a good thing for food storage.
    30 years ago I did a radiantly heated house with gypcrete on top of the subfloor, and while installing the tubing we decided to make one loop in and back out of the pantry because it had a 5'-6' exterior wall. This was the homeowners decision. The following winter he told me that this was a mistake and he regretted installing this loop. In his words, potatoes won't keep and start rotting fairly quickly.
  • mikespipe
    mikespipe Member Posts: 49
    I would think running a bare pipe either copper or pex Infront of the toe kick on the cabinets would be adequate. you could put a grille in front and reflective material behind you would not notice it . I'm a fan of electric radiant heat. and put it in bathrooms whenever I can. it would work well and it only goes under the exposed floor. leaving the light on works but would probably be annoying.
  • SiteReader
    SiteReader Member Posts: 1
    edited August 2025
    How about a full-length louver door? It'll let some air in, and they can be quite attractive. I used to install them when I did small-scale finish carpentry years ago. Was just thinking how they were solid wood, not hollow-core (like the ones on my present laundry room) in those days. I'm sure you can still find them. Should easily be thin enough to fit the pocket-door slot.
  • Stuart Rogers
    Stuart Rogers Member Posts: 56
    Maybe just…
    https://www.thespruce.com/best-ceramic-heaters-6831498
    Resident in 25-unit co-op, Toronto, built in 1925. In self-defence,"expert" on our 2-pipe steam system.
