Sloan Flushmate
Does anyone here have experience with Flushmates?
Is it normal to have a small amount of water in the bottom of the tank? I see some action down there when I flush it, but I can't tell if it's going up, or down, or both. I always thought these were 100% sealed and the tank stayed totally dry.
Is it condensation on the tank full of cold municipal water?
Usually i will see the tank dry, the water could be leaking from the small vacuum breaker on top or condensation if the tank was constantly running that's probably why they call you out there to check, the movement you see while flushing is just the prusser of the flush
There's some kinda thing on the side at the bottom that I see doing something. That's the problem I can't see if it's just peeing out a little each flush or if it's also draining at the end.
I have a feeling it's getting replaced by a toto soon.
No to both questions. It's a year after the recall and no condensation.
What toilet brand to you have now?
I have installed 3 Sloan units they didn't work properly and my supplier stop selling them to do many complaints, the once from Gerber using Eco flush work properly
Check this out you have a little prusser relive valve on the water inlet
It's a Gerber 1.6 and the place I see something happening is from that square area at the bottom in your diagram.
It looks like there is some sort of draft regulator there, maybe that is leaking
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
