Sloan Flushmate
ChrisJ
ChrisJ Member Posts: 17,265
Does anyone here have experience with Flushmates?
Is it normal to have a small amount of water in the bottom of the tank? I see some action down there when I flush it, but I can't tell if it's going up, or down, or both. I always thought these were 100% sealed and the tank stayed totally dry.
    mattmia2 Member Posts: 16,357
    edited July 2025
    no experience but pretty sure the water is supposed to remain within the device. there were ones that were recalled because they had problems with exploding, do you have one of those?
    old_diy_guy
    Is it condensation on the tank full of cold municipal water?
  • 9326yssh
    9326yssh Member Posts: 46
    Usually i will see the tank dry, the water could be leaking from the small vacuum breaker on top or condensation if the tank was constantly running that's probably why they call you out there to check, the movement you see while flushing is just the prusser of the flush
  • ChrisJ
    There's some kinda thing on the side at the bottom that I see doing something. That's the problem I can't see if it's just peeing out a little each flush or if it's also draining at the end.
    I have a feeling it's getting replaced by a toto soon.
  • ChrisJ
    No to both questions. It's a year after the recall and no condensation.
  • 9326yssh
    What toilet brand to you have now?
    I have installed 3 Sloan units they didn't work properly and my supplier stop selling them to do many complaints, the once from Gerber using Eco flush work properly
    Check this out you have a little prusser relive valve on the water inlet
  • ChrisJ
    It's a Gerber 1.6 and the place I see something happening is from that square area at the bottom in your diagram.
  • ChrisJ
    It looks like there is some sort of draft regulator there, maybe that is leaking
  • PC7060
    PC7060 Member Posts: 1,775
    edited July 2025
    should be dry. Water in tank is typically leaking plunger valve (#3 in IPB) on top of plastic tank.
    ChrisJ
  • 9326yssh
    That's an overflow drain if water is collected in the tank, if you only see water movement while flushing it's like I said only the prusser from the flush possibly causing some water to back up to the tank
    ChrisJ
  • Intplm.
    Intplm. Member Posts: 2,980
    Yes. It can be normal to see water at the bottom of the tank. If it's not leaking anywhere else and not affecting performance, I would not be concerned.
    ChrisJ
