Cámara Térmica (Thermal Camera Recommendations)
Claucia
Claucia Member Posts: 1
edited July 24 in Geothermal
Quiero comprar una cámara térmica. Tienen algunas recomdaciones?
    Steamhead Member Posts: 17,892
    From Google Translate:
    I want to buy a thermal camera. Do they have any recommendations?
    Consulting
    HeatingHelp.comClaucia1
    EdTheHeaterMan Member Posts: 10,780
    everyone seems to like Flir Cameras
  • ratio
    ratio Member Posts: 4,068
    I have one of these: https://www.tequipment.net/HikMicro/B20/Building-and-Industrial-Thermal-Imagers/?v=7463, works fine. I got an Amazon hard case for it with the pull-out foam; no complaints.
    I have one of the li'l plug-in-to-your-phone models, it works fine but I have to take my phone out of it's case to use it.
    hot_rod Member Posts: 25,359
    Flir has a good name and wide range of prices
  • pumpcontrolguy
    pumpcontrolguy Member Posts: 3
    I use one of these: https://www.hikmicrotech.com/en_us/industrial-products/pocket-thermal-camera/ Was a bit cheaper than a FLIR, but it's a good stand alone unit.
    Has both Thermal and visual cameras so it can blend the two together to give you a combined photo with gives good thermal but also good definition
    Here's some photos from it for reference.
    Nice Legs! 💃 looks like one of those legs is pretty hot.
    PeteAAlan (California Radiant) Forbes
  • pumpcontrolguy
    Quite toasty indeed. 50hp cooling tower pump is actually pulling perfectly acceptable amps (208v, 88a) but the wire and contactor is heavily corroded hence the high temps. Even better, you'll notice the date on that thermal photo is back in December and this customer is still running this pump 24/7. The cherry on top is that their second cooling tower pump has been completely down and that contactor is also burned up, so when this contactor finally burns up completely, they're going to have a fun emergency call
    9326ysshAlan (California Radiant) Forbes
  • ratio
    Unreal. I can understand limping along, but expecting failure, with no backup… I just… <smh>
