Which New Analyzer?
Hello All,
I am looking to replace an aging E-intruments Btu900- any suggestions? The unit has a replaceable O2 sensor which has been nice. Typically used for residential/light commercial mod-cons. It seems most brands have ups and downs. The calibration costs and downtimes seem unavoidable- so the best would be a model with longer service intervals. Not wanting to spend a fortune unless that up front price cuts down on calibrations. Thanks in advance!
I had a Bacharach Fyrite Pro for years; needed new, expensive sensors every year. In 2022, I switched to a Testo 300 and it's been excellent. It doesn't need sensors replaced and I haven't had it calibrated since I purchased it.
I bought it on Amazon; "Used, Like New" and saved $700. I also got the printer.
Two btu per sq ft for degree difference for a slab1 -
I have a 320. Like it a bunch… I get it calibrated bi yearly. ($300)
Send it to Testo from my supply house.
You may be able to get a used one as the 310 is discontinued.
Thanks everyone- I have been looking at Testo quite a bit. seems there is no way around the calibration fees, except the Bacharach insight and the fieldpiece cat45 have replaceable pre-calibrated CO sensors which means hopefully not shipping the unit away. I will do some more investigating!
https://www.supplyhouse.com/Fieldpiece-CAT45-CAT45-Combustion-Analyzer
I used Bacharach Fyrite Pro for years as well, no more. We had one that stopped working less than 1 yr old. sent it in, got billed about 700 or so. We moved to the Seitron.
ITYM https://trutechtools.com/, no?
YES
I’ll second TruTech. I get mine back no more than a week.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 985 Plumbing
- 389 Solar
