Repairing an aluminum coil
We have a trane four ton condenser coil that has a leak in the coil. the leak is in the discharge header on one of the tubes where it transitions from aluminum to copper. I know at one time Trane made a kit to couple these tubes back together, but I never had to use it and am wondering if anyone had used it with success, or brazed it closed? The coil is 4 ton, 410 a
thanks to all
I purchased some "Aluminum Braising sticks" once and had minor success sealing up a hole in a coil one time. I melted the channel closed and stopped the leak that way. not really a success in my mind but the leak was gone. As far as Aluminum to Copper… I remember that repair kit but never used one. Can't help you on that one except to show you this Trane repair kit on amazon.com
