Repairing an aluminum coil
We have a trane four ton condenser coil that has a leak in the coil. the leak is in the discharge header on one of the tubes where it transitions from aluminum to copper. I know at one time Trane made a kit to couple these tubes back together, but I never had to use it and am wondering if anyone had used it with success, or brazed it closed? The coil is 4 ton, 410 a
thanks to all
    never tried it never wanted to. All I know is aluminum melts real quick.
    zepfan
    you could also get an aluminum tube that someone else has transitioned to copper and solder the aluminum to aluminum. i don't know the details but i know with the right solder and flux you can solder aluminum to aluminum.
    zepfan
    edited July 2025
    I think you could also flare a piece of aluminum tubing and solder/braze it to the coil and connect the copper to the flare. Flare was how I dealt with the aluminum tubing in a mini fridge.
    zepfan
    EdTheHeaterMan Posts: 12,947
    I purchased some "Aluminum Braising sticks" once and had minor success sealing up a hole in a coil one time. I melted the channel closed and stopped the leak that way. not really a success in my mind but the leak was gone. As far as Aluminum to Copper… I remember that repair kit but never used one. Can't help you on that one except to show you this Trane repair kit on amazon.com
    zepfan
    oh, it is an aluminum tube leaking where it transitions to copper? I think you can flare the 2 and just use a flare fitting.
    zepfan
    $167 for the kit . used to buy a new coil for that price.
    mattmia2zepfanPeteA
    i was just pricing heavy gauge gutter parts and it is looking like it is going to cost around $1k
    zepfan
