Is a cap a must?
Cyclist77
Cyclist77 Member Posts: 252
As I get ready to install a SS chimney liner is a cap mandatory? My other flues,terracotta, don't have them and they are 4o years old. Never had a bird/animal situation. The reason I am inquiring is the SS caps are SO big and it would look very old on our cape cod style home.
Thoughts?
Thanks
    mattmia2 Member Posts: 16,346
    The cap keeps water out and prevents backdrafting in certain wind conditions.
    Jamie Hall Member Posts: 27,185
    If you don't have a cap or a screen, sooner or later you are going to have trouble. The other flues should be screened. If not, have it done.
    mattmia2heatdoc1HVACNUT
  • Cyclist77
    Thanks for your replies! Now it has me thinking about a project! So I have been considering learning TIG welding and the idea of fabricating a cap that will cover all 3 flues. I have a design in mind but pondering the way to attach it to the cap. I rebuilt the chimney 2 years ago and poured a new cap. The chimney is 4'x5' so there is alot of real estate up there. Not sure is fastening it directly to the concrete cap with say Tapcons?
    Thoughts?
  • ChrisJ
    ChrisJ Member Posts: 17,264
    edited July 2025
    Tapcons work good when used properly and in the correct applications.
    I've seen a lot of guys use them very wrong and then say they suck.
    I'd consider some stainless 1/4" Tapcons for that and don't overtighten them. I don't know where you're located but if your area gets very high winds I'd design accordingly.
    I'd also put silicone or osi quad around the heat and surface of the tapcon so it doesn't act as a path for water to get in the masonry cap.
    they are a little iffy in my structural cay tile basement walls.
  • ChrisJ
    Does the manufacturer say you can use them in that material?
    it seems to be intentionally impossible to find a statement about what materials yo can use their product on. it gives ratings in "concrete" and "block". If the fastener strips out it makes a good hole for a rawl plug.
  • ChrisJ
    edited July 2025
    I've only seen ratings in concrete (or CMUs which are concrete). That's also all I've ever used them in.
    That makes me think they're only intended to be used in concrete / concrete block.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,062
    Hi @Cyclist77 , Any chance of a photo of what you have up on the roof? I'm wondering what options exist for solidly attaching a cap (other than lead weights). 🤔
    Yours, Larry
  • Cyclist77
    Here is a pic of the top of the chimney just after we poured the cap.
  • Larry Weingarten
    Hi, It would take some sheet-metal skill to make a single cap, but it seems to me that stainless band clamps can be used to attach to the three outlets, pretty much eliminating any risk of damage to them. 🤠
    Yours, Larry
  • Cyclist77
    MMy Idea is 1 cap that spans all 3 flues.
    The idea of incorporating band clamps is a great idea!
    Larry Weingarten
