Caleffi Zone Valves
Member Posts: 4,564
Pretty much everything is o rings now-boiler feed/bfp, mixing valves, etc.
Does any supplier make a multi zone manifold like block? Or is every zone valve sold as individual?
I've got some Calleffi's running low pressure steam and have been quite reliable ( they make a higher temperature rated valve than the standard hot water models). Much more reliable than the outrageously priced multi piece commercial Honeywell zone valves on the same system that now, after being repaired twice over the same number of years, are getting replaced (with Johnson controls valves, Calleffi's can't handle larger steam loads).
To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
