Weird bathtub trap
9326yssh
9326yssh Member Posts: 46
First time I see a trap like this,
is it just a trap or was it doing something else for the size that it is it should to more 😏
Mad Dog_2
    mattmia2 Member Posts: 16,852
    edited July 2025
    It is a drum trap in tubular brass.
    Usually that means it is wet vented for an extended length or is arranged like an s trap where it goes down rater than directly in to a vented vertical section.
    hot_rod Member Posts: 27,489
    some hybrid version drum / ptrap? It would be interesting to see to see the inside
    Drum traps were common pre 1950s. Clog prone, hard to service.
    P traps tend to scour clean, I think drum traps have been banned for years in the codes
  • 9326yssh
    Yes interesting it wasn't replaced yet, but why would you make a trap so big what was the purpose
    was that the prototype for the traps we have
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,552
    That's look like what Manny called a Bell Trap...illegal...has interior partitions. If it didn't clog up or leak...no reason to replace it..Mad Dog
  • GW
    GW Member Posts: 5,184
    nice one, never seen that, been at it for 40 years
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    Intplm.
    holds more water so it is less likely to get syphoned dry from questionable venting arrangements
    9326yssh
  • ChrisJ
    ChrisJ Member Posts: 17,399
    edited July 2025
    According to NJ plumbing code, that looks like a partition trap. Kind of. But not really.
