solo 110
BryanGalde
Member Posts: 1
Got Error code B30,, Circulation pump was warm and making noise. Pulled pump from housing and there in no water in housing ? Something plugged? or where to look next ?
Leak somewhere and if something is supposed to provide makeup water automatically it isn't working.
Some pictures from a distance back of the boiler and the piping would help.
Sounds like the system has a leak and someone shut off the cold water fill. So no or not enough water to move the heat properly, causing the error.
One Pipe System0
