solo 110
Got Error code B30,, Circulation pump was warm and making noise. Pulled pump from housing and there in no water in housing ? Something plugged? or where to look next ?
    hot_rod Posts: 28,704
    What is the pressure reading on the boiler? Assuming you have a working, accurate gauge somewhere. A spinning circ with no water is a concern.
    Leak somewhere and if something is supposed to provide makeup water automatically it isn't working.
    Some pictures from a distance back of the boiler and the piping would help.
    109A_5 Posts: 4,759
    Sounds like the system has a leak and someone shut off the cold water fill. So no or not enough water to move the heat properly, causing the error.
