Need Carrier AHU variable speed fan motor/module/board
3 ton unit with AHU in the attic. 22 years old. $2500 repair estimate but something else could break while negotiating system replacement. Unless I can find parts cheap we're dead. Using window ACs for now. (I wish new stuff would last 22 years!)
    pecmsg Member Posts: 7,053
    the installing contractor determines how long equipment will last. 10 to 15 years is average, 20 years is possible.
  • GGross
    GGross Member Posts: 1,886
    If you are looking for parts it would certainly help if you included the model of the equipment you need parts for
  • WDGIBBS_M_E
    WDGIBBS_M_E Member Posts: 39
    I'll do that but must crawl into the attic & hopefully find the placard.
