Ever seen one of these??
We'll never see it all.
Are there any names on it?
Where is it located?
Consulting0 -
a "piddle catcher"!
humidifier but not very automatic. unless the bleeder is leaking.
For @Stet, Back in the day, we would need to work (or play) in the snow. We would wear something my father called galoshes over our shoes to protect them from the wet snow and ice. At the end of the day, that shelf at the bottom of the radiator might be a nice place to dry out your shoes and/or galoshes so they were dry for the next day!
As far as @psb75's contraption is concerned, That might be a Semi-automatic Humidifier. As the trough dries out, you just open the bleed port to refill for more humidity. It might be a once an evening thing. But eventually you would need to add water to the boiler if there was no auto feed in the basement.
2 -
That is a boot drying radiator. There was a shelf, or actually a pan across the bottom.
And of course the other thing is a humidifying pan. I believe a Chinese version is still sold from time to time, though it just hangs along the back of the radiator on S-wires, as the thin tube radiators that came out in the 30s don't have room for the tin pan.1 -
That little ledge could be for drying boots or shoes.
That's for drying plates or keeping them warm before they're served.
Consulting1 -
Automatic humidifier. Had these in a CT house!
- 121 Chimneys & Flues
- 15.8K Strictly Steam
