Combining supply lines to manifolds?
skyking1
Member Posts: 129
I have two manifolds at the West end, a 4 loop and a 7 loop.
I have a total of 11 (3/8) loops. Do I need to make 2x home runs of 1" to the heat pump, or can I run a single 1" and tee it there?
It is about 5.5 GPM, about 38' of run from the heat pump and plumbing.
Yes, the source is a ground source heat pump. Each manifold is the typical setup with balancing on the load and a circuit isolation valve on the return.
yeah, that supplyhouse chart is using some weird max fps, 4gpm is usually what is used for 3/4"
